TwinTurbo.NET: Nissan 300ZX forum - decided not to put front strut bar on after plenum pull
fuzzymonkey
on December 19, 2013 at 12:20 PM
Stupid things I do when working on a Z.
posted by z32z
on December 18, 2013 at 06:00 PM
because test drive.
didn't put the strut bolts on, oops.
z32z
18:00:36 12/18/13
we've all done stupid stuff at one time or another, like..
Stanky
19:42:55 12/18/13
I put teflon tape on new PCV vales so they would seal better
MrOzzie5183
20:37:16 12/18/13
oohh, that would make me so mad (n/m)
17:11:44 12/19/13
Forgot the boost leak tester
vorpalZ
21:18:48 12/18/13
Lol. Good times. (n/m)
MixManMash
07:17:38 12/19/13
Had fuel lines crisscrossed. Then forgot I had a towel over
LivinTheDream
09:28:30 12/19/13
I left a rag on top of the fan shroud once
-Grimm-
09:49:10 12/19/13
Didnt the Aux fan come on with key on and no ECU? (n/m)
BOOZTD 3
09:36:04 12/19/13
I stuck my thumb in the AUX fan once. It hurted.
Drk93TT
11:30:46 12/19/13
why? it wasn't your beerhand, you're good to go! (n/m)
17:09:59 12/19/13
There's been a couple but the latest was trying to
SammybTT(TN)
12:06:25 12/19/13
decided not to put front strut bar on after plenum pull -
fuzzymonkey
12:20:21 12/19/13
Torquing 18 bolts in sequence for your OSG Twin Plate...
ZinnZ32
12:20:45 12/19/13
Let my lift down with car onto a brand newly installed koyo
KongZTT GT28RS MD
12:54:14 12/19/13
Installed my heads on backwards, yes it can be done.
ZaXxon
14:52:50 12/19/13
Finished assembling a motor and installed, loosened cas
Krazyd27(Houston)
18:31:30 12/19/13
left my radiator cap loose and shut my hood then drove off
Whip
17:02:40 12/19/13
installed my SPL coilovers, forgot to pre-adjust them for
17:08:49 12/19/13
Pulled the oil cooler to drain it
Broke_as_****
00:09:50 12/20/13
R (n/m)
BoneZ (MD)
08:34:08 12/20/13
Dip stick left in when replacing oil pan gaskets. It only
CmyZ
08:34:29 12/20/13
Yup. I left the dipstick in while replacing an oil pan with
MixManMash
10:44:31 12/20/13
hey... you leave me out of this... let me admit my own
vorpalZ
23:33:45 12/20/13
I installed my rear crank sprocket washer backwards.
rojoloco (VA Beach)
09:16:57 12/20/13
Re: I installed my rear crank sprocket washer backwards.
blueridge
12:28:32 12/21/13
